throttle problems
Old Feb 29, 2008 | 06:00 PM
ga2404's Avatar
ga2404
Default throttle problems
I got my 60mm throttle body today and installed it. now the cruise control cable is real tight and it idles at 1500 and 2000 rpm, it also sometimes will just start to stutter like it has hit the speed limiter, how can i fix this or can I just cut the cable and order another one to replace it?
Old Feb 29, 2008 | 06:17 PM
GrApHite03's Avatar
GrApHite03
Default RE: throttle problems
ORIGINAL: ga2404
trace the cable back into the firewall. you must have it kinked or tangles somewhere. If not you have to choose between your TB or CC.
Old Feb 29, 2008 | 07:31 PM
ga2404's Avatar
ga2404
so my car will go back to normal other than no CC?
Old Feb 29, 2008 | 08:01 PM
GrApHite03's Avatar
GrApHite03
ORIGINAL: ga2404
Did you follow the CC cable back to the firewall?Only disable the CC as a last resort. If the CC connects to the new TB in the normal location than there shouldn't be any problems.
Trace it back... don't just look at it. take it off the TB and make sure its not twisted or kinked and trace it back with your hand. Its probably caught on something somewhere.
Old Feb 29, 2008 | 08:09 PM
ga2404's Avatar
ga2404
checked it 3 times and its not kinked or twisted at all
Old Mar 1, 2008 | 04:27 PM
ga2404's Avatar
ga2404
Thank you for help I cut the cable and it works fine now, miss my cruise control tho,does any one know where i can get another one to replace it and can i replace it myself?
Old Mar 1, 2008 | 04:31 PM
GrApHite03's Avatar
GrApHite03
ORIGINAL: ga2404
If there was nothing wrong with your other one... than a new one isn't gonna solve your problem.
Old Mar 1, 2008 | 05:29 PM
01neon01's Avatar
01neon01
wow i wish i had seen this earlier. you didnt have to cut the cc cable. all you had to do was adjust it in order to get it to work properly. iyou can adjust the ammount of cable by messing with the gray tab that you can pop off in order to give it some slack so its not so tight
Old Mar 1, 2008 | 09:24 PM
inthewerks's Avatar
inthewerks
man.you cut your cable? i was willing to bet 500 invisible dollars that you didnt install your tps sensor right. if they are off by just a little bit, they will cause that rpm fluctuation you are talking about.
Old Mar 2, 2008 | 01:18 PM
ga2404's Avatar
ga2404
01neon01 its ok i wasn't even able to drive my car before i cut it, but oh well i saw a replacement cable on ebay for $20, its for an r/t tho will it fit on my sxt?
