hvac led done (sortof)!!
Old Mar 8, 2008 | 09:17 PM
eaks's Avatar
eaks
Default hvac led done (sortof)!!
Hey guys.. well i just worked on my HVAC led modifications.. I used to have it setup but didn't really like how bright it was so re did them (2 with 194 bulbs and one with just a 5mm blue led)..
Heres some pics!
BEFORE:
http://i20.photobucket.com/albums/b2...g?t=1205029134
http://i20.photobucket.com/albums/b2...g?t=1205029164
NOW:
http://i20.photobucket.com/albums/b2...g?t=1205029187
http://i20.photobucket.com/albums/b2...g?t=1205029204
I like the even glow now and not being blinded like before.. removed all the wiring for the previous install!
Now when I removed my HVAC peice (the entire white peice) i broke one of the conectors for the wires and i also broke the peice that holds to the 2 wires there so i need to pickup another one..
let me know what u guys think!!
Old Mar 8, 2008 | 09:49 PM
srtgtr34's Avatar
srtgtr34
Default RE: hvac led done (sortof)!!
nice i like it, what other colors can you get?
Old Mar 8, 2008 | 10:16 PM
eaks's Avatar
eaks
I believe blue is the best becuase there is a blue film on the controls such as the gauge cluster and blue is the theme im going with.. Im sure you can scrape the film off and use any colours you want tho.. starting from the right to the left i used.. 1 194 wide angle LED (white), then next to it i used 1 194 Blue wide angle led and next to it i used a 5mm 5000mcd (i believe) led with a resistor (The reason i didn't use a 194 is becuase the space for the socket is really small and you cant work on it the way it is and the led will fit threw the hole.. whereas with the 194 bulbs i had to install them threw the hvac panal with the socket in)..
Old Mar 8, 2008 | 10:35 PM
Mat00ES's Avatar
Mat00ES
Looks good, I hope mine comes out some what decent when I done with it.
Mat
Old Mar 9, 2008 | 10:13 AM
contagious19's Avatar
contagious19
looks good, i need to get some leds
Old Mar 9, 2008 | 04:38 PM
DouglasSXT's Avatar
DouglasSXT
Looks good, really like the bright one though! I need to do my HVAC lights soon as well to go with the gauge cluster ones.
