will a 2nd gen trans work in a 1st gen?
Old Mar 11, 2008 | 08:58 PM
whtdoesitmatter's Avatar
whtdoesitmatter
Default will a 2nd gen trans work in a 1st gen?
i have a wrecked 2nd gen 5 speed neon...i was wondering if that trans and everything will work as a direct swap in a 1st gen both SOHC
Old Mar 11, 2008 | 10:36 PM
GrApHite03's Avatar
GrApHite03
Default RE: will a 2nd gen trans work in a 1st gen?
00-02 will work with te first gen wiring... may have to re-wire a few sensors. not sure. 03+ will not work with first gen wiring.
Old Mar 15, 2008 | 04:29 PM
03neonRT's Avatar
03neonRT
For a near "direct swap", the manual transmissions from the 2000 model year Neons is your only option (and the 1st Gen wiring/sensors like Graphite stated)...otherwise with an 01-02 tranmsission you'll have to swap over the hydraulic clutch setup.
