Intake manifold
ORIGINAL: blazingdisciple
So that's the best that's around? I also plan on putting a turbo on my 2nd gen and I guess you gotta pay to play...
ORIGINAL: Izero
or you can goto dodgepart.com and get the r/t intake manifold for $182 ? idk
ORIGINAL: Izero
what exactly are the butterfly actuators and the motor to operate them?...
In order to open/close the secondary runners in the Intake manifold there are butterfly satuators that open and close and that are powered by a small "motor". You'll also need two relays, lots of wiring, a TPS/WOT switch, and a RPM window switch for it to open/close at the correct RPM points (the R/T PCM would normally control this function).
Your looking at anohter $200-$300 for the butterflies, motor, and all the components to get it fully functional like the real thing...thats why used Magnum Intake Manifolds with the butterflies and motor sell for $250-$300+ on forums when they pop up...bare used Magnum Intake Manifolds out there sell for around $125-$150 though...
why is it that the regular neons dont have these butterflies then? and would you really need them if it was turbo'ed?.... in all honesty someone really needs to make a direct fitting intake manifold.... b/c the fact that the indy says its direct fitbut in reality it is a pain in the @$$ to install then what good is it?
Agreed. But its cheaper and some cases they conduct heat better (not perform betterthough)if they're made out of the correct composite material. Hell my parents 5.7 HEMI Magnum has a plastic composite intake manifold which I wasnt too happy to see...but oh well its not my car lol.
