Engine Code Help
Old Mar 28, 2008 | 11:55 PM
Baddog44's Avatar
Baddog44
Default Engine Code Help
P0038 HO2S Heater Circuit High Voltage Bank 1 Sensor 2
can anyone help me out witht his on what it means...came on after spark plug install
Old Mar 30, 2008 | 12:53 PM
Baddog44's Avatar
Baddog44
Default RE: Engine Code Help
bump anyone?
Old Mar 30, 2008 | 05:55 PM
jmja9281's Avatar
jmja9281
maybe change the Selenoid.
Old Mar 31, 2008 | 08:06 PM
03neonRT's Avatar
03neonRT
The CEL is saying its a problem with the heated upstream O2 sensor leading off the cylinder head...check to make sure the spark plugs you installed are the corect type and are torqued to spec for starters.
Old Mar 31, 2008 | 09:29 PM
Baddog44's Avatar
Baddog44
ok here is the wierd thing...i cleared the codes the same night i posted this...it stayed off for the night then came back on the next day and stayed on...BUT when i went to go fill up my gas tank it turned off the code after i started it back up and hasnt come on since...you think it was just the new plugs adjusting?
