turbo question....
Old Mar 29, 2008 | 05:29 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
Default turbo question....
alright i have decided to use the small turbo that i got that was not the right turbine.... but anyway, i have a question....
can i block off the coolant lines that go to the turbo if they r in the housing??? willl that hurt anything??? by just running oil and no coolant threw it, i know it will run hotter this way, but will it hurt the turbo, and will it hurt anything else??? i was thinking that spikeymikey capped his coolant lines off but i can not remember for sure?????????
thanks for the help, i am hopin to have the car up and running by the end of the weekend.. if not hopefully midweek.....
Old Mar 29, 2008 | 07:26 PM
spikeymikey87's Avatar
spikeymikey87
Default RE: turbo question....
yea i ended up capping mine too. it should be fine. it will run a little hotter, but most turboes are only oil cooled anyway. you should have coolant goin through there, but if there is none, no biggie
Old Mar 29, 2008 | 07:37 PM
GrApHite03's Avatar
GrApHite03
I never ran coolant either... just invest in a turbo timer if you haven't already.
Old Mar 29, 2008 | 07:39 PM
fox02neon's Avatar
fox02neon
Why would you not? Does it just not line up? I found that on my turbo the otherside of the coolant lines is capped.
Old Mar 29, 2008 | 07:46 PM
GrApHite03's Avatar
GrApHite03
ORIGINAL: fox02neon
I did not because i felt it wasn't needed... as long as there is oil running through there will be enough to cool it. the coolant is for extra protection. Turbo timers are made to run the oil a while before shut down to cool the turbo.
As far as your capped coolant line, i'm not sure what you mean... is the turbo on the car and running now? are you feeding coolant but have no return?
k3v
Old Mar 29, 2008 | 08:54 PM
dtjackten's Avatar
dtjackten
yeah, i am going to cap both lines... easier for me this year, and i may just do the same next also.... not really sure though, anyway.... thanks alot for ur help..... i will snap some pics and put a new post up when i get the car finished and almost ready for start up......
i love this forum sometimes....
