2001 Neon oil drain plug
Old Mar 30, 2008 | 10:15 PM
neisg1's Avatar
neisg1
Default 2001 Neon oil drain plug
I want to pick up a spare engine oil plug to have on hand as I do most of my own oil changes and live 30 min, from the city. Just thought it would be good to have a spare. The problem is one supplier says it's 12mm x 1.75 and the other says 14mm X 1.5 can someone verify the size.
Old Mar 31, 2008 | 02:29 PM
Izero's Avatar
Izero
Default RE: 2001 Neon oil drain plug
nope.... you'll have to ask the dealer b/c thats an odd part that usually the dealer is the only one that carries the right size and thread pattern.... and you shouldn't need a spare unless you're over torquing the bolt in the first place
Old Mar 31, 2008 | 03:06 PM
djmagic's Avatar
djmagic
its like 8 bucks at the dealer
Old Mar 31, 2008 | 08:04 PM
bone33's Avatar
bone33
not only can they tell you the right size, but they also carry them in stock at NAPA.
Old Apr 23, 2008 | 04:46 PM
neisg1's Avatar
neisg1
It is a 14mm X 1.5the 12mm x 1.75 was a wrong store listing
