MFS wires
Old Apr 1, 2008 | 03:37 PM
Kalevra's Avatar
Kalevra
Default MFS wires
I dont have the cash at the moment to buy the piggyback, so what wires would I need to cut to rig up an external switch. is the switch all I need?
EDIT: for the headlights and fogs
Old Apr 1, 2008 | 11:40 PM
Kalevra's Avatar
Kalevra
Default RE: MFS wires
C'mon!! I need the wires for the fogs and headlighs!! please!
Old Apr 2, 2008 | 12:15 AM
Baddog44's Avatar
Baddog44
ive never done it but im assuming thats all u need...all you gotta do is take the low beam (and high beam if u want a switch for that) pin from your multifunction switch on yer turn signal pull it and wire it up to an I/O switch and then pull teh pin for yer foglight and wire it the same way to yer external switch
Old Apr 2, 2008 | 12:28 AM
Kalevra's Avatar
Kalevra
Ok, but I need the wire colors/location to do that.
Old Apr 2, 2008 | 12:35 AM
Baddog44's Avatar
Baddog44
hold on let me see if i can pull something up....low beams are gonna be pin #16 and i think it is violet with a white strip let me check fogs
Ok fogs are pin #14 its pink with a light green stripe on it or its light blue one or the other
Old Apr 2, 2008 | 12:40 AM
Kalevra's Avatar
Kalevra
I need a deff. not an I think :P now... how do I go about wiring it up? like... are there 2 wires, or just one?
Old Apr 2, 2008 | 12:44 AM
Baddog44's Avatar
Baddog44
ORIGINAL: Kalevra
ok well i know for sure bout the headlight wire and its only 1 power wire...for the low beam....it wouldnt be hard just find yerself a switch and instead of it going to the multifunction switch just run it to yer external switch
Old Apr 2, 2008 | 12:56 AM
Kalevra's Avatar
Kalevra
Ok, now color/location and a description of the connector... does it go as you're looking as the butt end of the connector as it were if it was connected
< towards stalk/drivers door
[Connect clip]
[1 2 3 4 5 6 7 8 9 10]
[11 12 13 14 15 16 17 18 19 20]
or... is it flipped? I'm going to bug the **** outta you on this one. lol
Old Apr 2, 2008 | 02:22 PM
Baddog44's Avatar
Baddog44
ok now the connector is going to be directly behind yer turn signal switch....make sure its a grey connector and not a black thats lower towards the bottom...i dont remember if the the first pin starts from the drivers side or the passenger but when u pull the connector it has the pin numbers on the connector itself
Old Apr 2, 2008 | 02:36 PM
Kalevra's Avatar
Kalevra
Ok, I need the pin numbers and how to wire up a swtich.
do I connect one end of the switch to the power and the other to a ground?
