Apexi AFC NEO problems
Old Apr 1, 2008 | 05:17 PM
Dragon Type R's Avatar
Dragon Type R
Default Apexi AFC NEO problems
Hey Guys ...... I having a prob with my AFC NEO ....I'm pretty sure that I have it installed right .... it works fine .... but when I go to WOT it screws up my map voltage ..it doesnt seem to do anything but when I idle and rev it, it backfires ...then if I drive it for another 15-30 mins then I get an error, that I have aMAP high voltage.. but if I shut off the car immediatly its fine .... no error comes up ....I'm thinking that the setting are wrong .....I have it set to pressure10 in/out ..no setting done to the a/f map ... I stumped ... can somone help ....PLEEEAAASE!!!![&o] ......... Thanx
Old Apr 1, 2008 | 11:41 PM
Izero's Avatar
Izero
Default RE: Apexi AFC NEO problems
i have no idea b/c i dont have one... but i'd say edit your settings a little lower... check to make sure you have the high and low tables connected right... but im betting its your settings...
