Car Problem
Old Apr 1, 2008 | 05:45 PM
irishking's Avatar
irishking
Default Car Problem
Hey guys and girls. Quick question maybe someone could help with. I notice my car putting when i reach 3,000 rpms or higher. It only happens it seems when it rains or when it had rain the night before. I drove to work today everything was fine untill i had to go up a hill. I tried to give it more gas and it starting putting. I finally got up the hill and figured id floor it to see what happened. Well after I floored it the car went no where almost struggling to get past 3,000 rpms. I have people telling me its the ignition coil, spark plugs, spark plug wires, & air/fuel (car not getting enough of both). I have Msd spark plug wires, msd ignition coil, and a short ram air intake. Any ideas guys/girls. The car has no problem hitting 70 80 90 mph but it takes longer because the fact I have to tap the pedal in order to go. I cant give it the normal pedal to the metal lol. If ne one could give me some ideas please do so.. Thanks.
Old Apr 2, 2008 | 05:42 AM
N30N's Avatar
N30N
Default RE: Car Problem
well check your intake cause it sounds like the engine might be flooded by fuel.sometimes if you get bad gas it will run like **** too.i had a friend that got his intake wet and the car got to much water humidity.another thing to check is your plugs, it could be miss-firing which is bad.im sure someone else will hop on this cause ive only had my neon for 2 weeks...good luck
Old Apr 2, 2008 | 11:24 AM
spikeymikey87's Avatar
spikeymikey87
how old are the spark plug wires and when was the last time you changed your plugs?
Old Apr 2, 2008 | 07:07 PM
GroundControl's Avatar
GroundControl
check the plugs and wires first. I had a bad wire once and it only reved to about 3k then crapped out. It had nothing to do with wet weather though.
Old Apr 3, 2008 | 05:16 PM
irishking's Avatar
irishking
I replaced the spark plug wires and ignition coil about a year or so ago. I upgraded the stock wires and coil with msd wires and coil. But its weird it only happens when it rained or rained the night before.
Old Apr 3, 2008 | 05:35 PM
GrApHite03's Avatar
GrApHite03
If you're having car problems
I feel bad for you son
I got 99problems
but a car aint one
Old Apr 3, 2008 | 06:37 PM
ewetho's Avatar
ewetho
Sounds like Ignition if it only happens after a storm. Check carefully. Have read numerous reports of MSD coil going out after a year or so. Try swapping you OEM coil back in and see if it clears up. Then try new wires.
Old Apr 3, 2008 | 06:51 PM
irishking's Avatar
irishking
Should I just put the oem wires and coil back on and wait till it rains again to see what happens.
