cyl 2 and 3 firing, 1 and 4 not
Old Apr 7, 2008 | 09:07 PM
2000problems's Avatar
2000problems
Default cyl 2 and 3 firing, 1 and 4 not
I changed everything i could, new ecm,ckp,cmp, wiring harness, spark plugs, coil. Stilli cant get cyl 1 and 4 to fire. What else could be the problem, am i missing a ground somewhere or is there some kind of test i could do to check everything. have any of you ever had a problem like this or similar to this?
Old Apr 7, 2008 | 09:57 PM
ewetho's Avatar
ewetho
Default RE: cyl 2 and 3 firing, 1 and 4 not
At that point you need to check into it with a full blown scan tool with live data and even a scope to see what is going on. Checking primary voltage on coil and injectors etc...
Check CMP, and CKP to see what your signal looks like.
You changed quite a bit of stuff, but how's the injectors??? Have you swapped them around yet???
Old Apr 7, 2008 | 10:10 PM
2000problems
gas is flowing fine, but i just cant get the coil to fire on 1 and 4. i dont get it.
Old Apr 8, 2008 | 12:28 AM
Dragon Type R's Avatar
Dragon Type R
you should try a compression test and a leak test .... might not be the ignition....
