Engine codes
Old Apr 17, 2008 | 07:37 PM
Andpto's Avatar
Andpto
Default Engine codes
well ill just replaced my water pump and timing belt and got these codes
P1846 Transmission Transfer Case Contact Plate 'A' Circuit Failure
P1490 Secondary Air Relief Solenoid Circuit Malfunction
does somebody know any info?
Old Apr 18, 2008 | 03:48 AM
contagious19's Avatar
contagious19
Default RE: Engine codes
i hope i dont get those codes when i change my stuff
Old Apr 19, 2008 | 08:48 AM
03neonRT's Avatar
03neonRT
The P1490 is an axillary emissions control system malfunction code, but I wouldnt worry about it too much. As far as the P1846 goes though, I'm 99% sure a FWD transmission doesn't have any kind of "transfer case" (only AWD/RWD), so I don't really know why its flashing that one either...
Old Apr 19, 2008 | 09:20 AM
djmagic's Avatar
djmagic
is the cel on? If not just dissconnect the battery maybe?
Old Apr 19, 2008 | 06:09 PM
Andpto's Avatar
Andpto
Well the cels just went away last night when i was on my way home....
so i guess everything is fine now
Old Apr 20, 2008 | 01:48 AM
djmagic's Avatar
djmagic
did you do the code check again?
