PSI for Dodge Neon SXT
Old May 1, 2008 | 10:53 AM
gilligan's Avatar
gilligan
Default PSI for Dodge Neon SXT
Hi,
What's the best PSI for Dodge Neon SXT?
Thanks for your help.
Old May 1, 2008 | 02:54 PM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: PSI for Dodge Neon SXT
I'm gonna assume bets PSI for your tires. If so it should be somewhere around 32-35. It should also say on the tire what the best pressure for them is.
Old May 1, 2008 | 04:42 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
or is he talking turbo psi?????? on a stock block seven with a good tune, with a great tune... 10 MAX.....
but what exactly r u lookin for??
Old May 1, 2008 | 07:25 PM
Freerider's Avatar
Freerider
10 is pushing it. If it would be a daily driver 7-8 is what I recommend on a blown set-up.
For tires, at auto-crosses i dialed in a combination from 32-35 on the tires. I whent with just about 35's in the front, and 32-33 psi in the rear. I then drove, did some hard cornering on a road slightly out of town, then went back and adjusted. I repeated until the handeling felt good.
It is really all up the driver, the cars modifications, and what you intend to do. So trying to test it out on similar conditions is good. Usually auto-crosses come out with course maps a few weeks to days in advance. Knowing this, and after you have been to a few races, you can usually tell what you are going to need and know how to adjust your tire pressure accordingly just on how it handles.
If you have changed from stock tires, you are seriously going to have to do it all by feel.
Old May 1, 2008 | 09:04 PM
dtjackten's Avatar
dtjackten
like i said 10 on a GREAT tune.... graphite did it... but u better also know what u r doin to push it that far, i was runnin 7... safe for me...
Old May 1, 2008 | 09:27 PM
inthewerks's Avatar
inthewerks
if its a stock motor than i wouldnt go past 8 psi on a turbo for daily driving. maybe notch her up to 9 or 10 when at the track but 10 or higher is really pushing it without bottom end mods.
Old May 1, 2008 | 09:31 PM
dtjackten's Avatar
dtjackten
well when mine runs inthewerks... mine cooks mustangs gt's
sorry i had to....
next year maybe a vette or to...
Old May 1, 2008 | 11:30 PM
fox02neon's Avatar
fox02neon
I worked a les schwab for a while we ran 32-35 psi in the tires. Like stated before it is labled on the tires its self.
Turbo, I have an 02sxt and I am running about 5 psi of boost for the daily driver. Enjoy
