solid motor mount
Old Jan 16, 2005 | 01:23 AM
elric62285's Avatar
elric62285
Default solid motor mount
What do ya'll think of a completely solid motor mount. all metal no rubber. would it be worth the extra vibration and noise?
Old Jan 16, 2005 | 02:55 AM
casper's Avatar
casper
Default RE: solid motor mount
I just put the AFX in mine, I put in the solid race front mount and solid bobble from howell. There is definatly a lot more vibration, I have a MTX and anything under 2500 - 3000 RPM there is a vibration if you are on the gas, if you are just cruisin its fine. The vibration is like what you would get if you were in 4th at like 15-20 MPH except louder. They do firm it up quite a bit and all but eliminate wheel hop, but it is taking some gettin used to.
Old Jan 17, 2005 | 06:13 PM
casper's Avatar
casper
OK, I found the vibration, my hood was not properly adjusted and was vibrating. After I fixed that there is some vibration, but its a lot better.
