how hard is it to change a fuel pump
Old Jun 13, 2008 | 03:07 PM
culthuu's Avatar
culthuu
Default how hard is it to change a fuel pump
How difficult is it to change a fuel pump on a 2000 Neon ES? I know you have to take off the fuel tank but is this something easy to do in a driveway with just a couple of ramps and a jackstand? Do you have to move, remove the exhaust or any of the suspension?
Old Jun 13, 2008 | 03:21 PM
tspeed109's Avatar
tspeed109
Default RE: how hard is it to change a fuel pump
If I remember I do not think you have to remove the tank to replace the fuel pump. Mine was in front of the passenger rear tire in a box.
Old Jun 14, 2008 | 10:43 AM
spec_ops57's Avatar
spec_ops57
According to my Haines manual it is infront of the gas tank somewhere, and you do not have to remove the tank to reach it. Although I didn't read too far into it as I was just looking at the fuel filter part.
Old Jun 14, 2008 | 08:32 PM
spikeymikey87's Avatar
spikeymikey87
i did it, yes, you have to take your tank off. its really not all that hard, just make sure you run your tank down to E and release the pressure before you start working on it. also, dont force things, because i broke a tube for the evap and i had to replace it. it took a few hours to do the whole project
