2003 Dodge Neon (automatic) - Transmission/Brake issues
Old Jun 15, 2008 | 11:42 AM
dnoyes's Avatar
dnoyes
Default 2003 Dodge Neon (automatic) - Transmission/Brake issues
I just had brake and transmission work done on my car. I took it to a Chrysler dealership.
ISSUE: Converter failed and debris throughout transmission
RESOLUTION: 21000733 Transaxle, Automatic - Remove and install for recondition 4-speed transaxle
They also resurfaced rotors and drums, did an alignment, and put in brand new air cleaner (the whole unit).
This is what I am seeing after it was "fixed".
Transmission [ul][*]worse fuel economy (~1.5 mpg)[*]shifts are harder[*]shifting at points it never used to (even when new)[*]less power[*]little kicks/jumps when above 60 mph (with gas pedal in same position) [/ul]Brakes [ul][*]significant pulsating between 40-60 mph (passengers have noticed it)[*]have to depress pedal further for any real braking to happen[*]takes longer to come to a complete stop[/ul]My car has been a nightmare the past year. It only has 59K miles on it. Anyone have any ideas? I'm about ready to throw in the towel and sell it and get a toyota.
Old Jun 15, 2008 | 02:27 PM
spec_ops57's Avatar
spec_ops57
Default RE: 2003 Dodge Neon (automatic) - Transmission/Brake issues
Take it back to the dealership and raise hell
Old Jun 15, 2008 | 04:40 PM
Undesolved's Avatar
Undesolved
yeah take it back to the dealer and tell them whats happening
Old Jun 17, 2008 | 05:02 PM
tspeed109's Avatar
tspeed109
It sounds as if they left off the vacuum lines or put them on wrong on the transmission.
hope this helps.
