Clutch pedal
Old Jan 22, 2005 | 04:29 PM
nippondrifterae111's Avatar
nippondrifterae111
Default Clutch pedal
my neons clutch is fine but the pedal is loose and freely moves more than it should and squeeks when it is pushed on i kno how to fix the squeeking but how to i tighten the pedal or do i have to get a new assembly
Old Jan 22, 2005 | 05:36 PM
casper's Avatar
casper
Default RE: Clutch pedal
Use WD-40. There is no adjustment for the pedal.
Old Jan 24, 2005 | 02:00 AM
ewetho's Avatar
ewetho
One other solution which lasts a bit longer but you must be careful when lubing is to use antiseize. Clean that out of carpet and you are the man.
