2001 neon excessive current draw
Old Jul 18, 2008 | 10:21 PM
flour999's Avatar
flour999
Default 2001 neon excessive current draw
My neon has excessive current draw when it is off. The underhood #13 fuse (INT/LMP) is the problem circuit.
When the fuse is in, the current draw is more than 10 times that of when it is pulled.
No internal lamps are on when the fuse is in. I also removed the radio and cd player, but the draw is still the same.
Is there anyway i can find out what is controlled by that fuse? Or what the problem may be?
I have to leave the fuse pulled or my battery will drain in a day.
Also just wondering why the underhood #13 fuse has that yellow plastic thing on top?
Old Jul 19, 2008 | 04:18 AM
Adionik's Avatar
Adionik
Default RE: 2001 neon excessive current draw
we only know about cai installs....we have no knowledge of technical matters lo siento
Old Jul 19, 2008 | 04:39 PM
Exubus's Avatar
Exubus
Sounds to me like you have a short somewhere. I would isolate/remove everything one by one and see if any improvement occurs. If not, start looking for a worn wire up against a ground somewhere. I hate electrical/wiring flaws...
