Problems
Old Aug 24, 2008 | 01:45 AM
Adionik's Avatar
Adionik
Check the CV boot...my friends RSX Type-S had his CV boot tear, started leaking fluid and his clutch stopped working
but I can bet my freaking life that it's not the cat...These people need to go do this
Old Aug 24, 2008 | 01:46 AM
Exubus's Avatar
Exubus
Um, he he nevermind I will wait this one out...
Old Aug 24, 2008 | 01:49 AM
djmagic's Avatar
djmagic
all the boots look fine. Smallblock it only bogs when i stop like it is just about to die.
Old Aug 24, 2008 | 01:51 AM
Adionik's Avatar
Adionik
Did you check the PCV valve hose? Mine was twisted the other day...kept wanting to stall
Do you lose power to the cluster and lights when it stalls?
Old Aug 24, 2008 | 01:52 AM
smallblockfreak's Avatar
smallblockfreak
Then i doubt it's the cat cuz when mine went it was WOT it would bog and the cat actually broke in pieces and logged itself in my muffler. Maybe your clutches aren't slipping? Causing a load and wanting to kill the engine.
EDIT: meant the torque converter isn't slipping.
Old Aug 24, 2008 | 02:34 AM
Exubus's Avatar
Exubus
That's what I thought earlier too... maybe a problem with the solenoid on your TC, or maybe a sticking bearing, etc... something around the TC causing it to take a dump on you.
Old Aug 24, 2008 | 02:36 AM
djmagic's Avatar
djmagic
pcv valve hose? Where is this located at. I'll put the torque converter on the list if it keeps getting worse. Either me and my dad or a shop can just swap it out with a new one right?
EDIT: Adionik no loss of power to the cluster
Old Aug 24, 2008 | 02:38 AM
Exubus's Avatar
Exubus
PCV hose runs from the side of your valve cover into your air cleaner box.
You can replace the torque converter, its just a question of whether that's the problem, or the solenoid, or the slip bearing, etc etc...
Old Aug 24, 2008 | 02:51 AM
djmagic's Avatar
djmagic
ok thanks for the hose info iowa. And dang on the torque converter. I'm hoping that it can run decent for at least 2 more years. Hose looks fine
