Spark plug wire problem
Old Aug 28, 2008 | 07:51 PM
jmja9281's Avatar
jmja9281
Default Spark plug wire problem
Hey everyone how are you all doing. I am experiencing a problem with my # 3 spark plug wire. I recently took off my Valve cover and bolted it back on the head. I bolted on the coil and connected all the wires in thier proper order however my # 3 wire dose not snap onto the plug. Is this problem normal with the wires? I have a 2004 dodge neon 2.0 and Mileage is creeping up to 40,000. The wires are the original set from the dealer. If I buy a new set of wires will this resolve my problem? If any one can help with this, it will greatly be appreciated. Thanks.
Old Aug 28, 2008 | 10:32 PM
bone33's Avatar
bone33
try one of the other wires, if it works, then the #3 connector is broken.
a new set of wires wont hurt it and can be had for $20.
Old Aug 28, 2008 | 10:36 PM
bone33's Avatar
bone33
also, make sure the connector hasnt snapped off and is stuck to the spark plug.
Old Aug 28, 2008 | 10:38 PM
the_mechanic_33's Avatar
the_mechanic_33
New Member
U could try and squeeze the terminal end (careful not to hurt the boot) tighter then check the resistance of said wire.
2280 ohms to 7290 ohms.
