Car vibration, wtf??
Its always from the front of the car, which is why i had the motor mounts looked at. It happened previously for about a month til i had a MAJOR tune-up done, then stopped but recently has started again.
I had this problem too. And it just got worse and worse. I got my car on a rack at school, took out the lower and upper motor mount/shock struts and had my instructor inspect them in comparison to the new ones from Mopar (I bought them on a hunch). He said they were fine so I returned them. I re-adjusted the other ones to the proper engine position and all and still had this problem. Took it to another mechanic I knew, turns out it was the other (harder to get to) mount that's under the battery and transmission. Make sure that one gets checked too!
Nuetral, motor mounts, do basic tune-ups and maintenance on your car.
Seriously though since you never directly answered... is it really idling at 3000 rpm? If so, then it sounds like you have a completely different set of issues...
