the neon is back!!! well atleast my neon is...
ya thanks, im back in it, but it just seems to keep not wanting me in it......
see the following... http://forum.2gn.org/viewtopic.php?t=35174
Well, we basically removed the bumper cover which bolts to the fender ...3 bolts per side....and a handfull somewhere on the bottom of the number cover...then the bolts for the bumper itself or the crash bar or whatever just unbolts from the frame...there are 2 brackets at the base of the radiator, a couple at the top, and a couple rubber hoses with clamps,the bottom black hose should be removed while laying under the car....then the part that I found most difficult is were the 2 silver lines run to the bottom of the radiator that had funky long bolts through them...then disconnect the power cable running to the fan and it SHOULD pull right out...but I may have forgo a couple things
