Headers for my neon help please
Just putting on a header will not blow your tranny... not in a Neon with no other big modifications.
Rule of thumb: Short-tube headers are good for increased horsepower, and mild torque increases over the stock manifold.
Long-tube headers are usually for higher flow, for maximum horsepower potential over a short-tube, but less torque increases than a short-tube header.
Put a CAI and a new cam w/new valve-springs in your car if you want to see more potential out of that header btw.
it will bump your regular neon up to a r/t's HP
oh damn for real?ok so for the exhaust you mean the whole system or like just a muffler?? yeah all i really need right now are the wires i was hoping to maybe scoop up an msd coil and from there putt the better wires
CAI and exhaust alone, regardless of a tune-up, won't give you 150 hp (like the R/T)... you need an aftermarket cam at the least, and maybe even a larger TB to reach that consistently.
dude more airflow out and in will help your car so much...
the muffler is sideways..the only other bend is by the cat to take the pipes through to middle up to the manifold.now by cutting off the exhaust your letting the air strait out..it comes out the drivers side.less bends ='s more flow...our pipes are 2.25" now im not saying redo the whole thing...becase if you put duals or bigger pipes it will be louder but you'll lose so much back pressure it will hurt your performance...the regular neons push out 132 hp and the r/t's push 150 even...so CAI and exhaust with decent wires and plugs(ask everyone and NGK v-powers run best)with some FS oil and youll beat a stock R/T neon guarenteed
ill disagree.i beat an r/t stock when all i have is
mobil 1 FS oil+filter
trani fluid change
ngk v-power plugs
strait pipe exhaust
CAI
new wires
coolant fluid change
and cleaned out my system with sea foam through the intake
trani fluid change
ngk v-power plugs
strait pipe exhaust
CAI
new wires
not to be a post ***** but i barely got him and it was in good shape.hes not a big tuner but he keeps it clean...i dont wana argue but thats all i have to say...primedneon PM me if you ever need help and ill get out of here
