BRAKE indicator light comes on when starting in 1st gear.
Old Oct 17, 2008 | 08:26 PM
Michelangelo's Avatar
Michelangelo
Default BRAKE indicator light comes on when starting in 1st gear.
I'm new to the site and excited to find it. I just bought a very nice 2000 Plymouth Neon 5 speed, 16 valve/4 cylinder with 107k miles. Timing belt and water pump have been done. Very, very well maintained car.
When we start up and leave a stop from 1st gear the red BRAKE light on the dash illuminates and rings as I start my acceleration in first gear. Once I shift to second gear it goes off. The emergency brake is completely disengaged.
Anyone have this problem or know of the fix for this annoyance?
Old Oct 17, 2008 | 09:14 PM
smallblockfreak's Avatar
smallblockfreak
how much brake fluid is in the master cylinder?
Old Oct 17, 2008 | 10:16 PM
Michelangelo
Nice call. I'll double check that but I'll put money on your call that it's the problem.
Thank you!
Old Oct 17, 2008 | 10:24 PM
smallblockfreak
your welcome sir. I hope that is the only problem but if it is low you might have a leak so if its the problem then pump your brakes up and check for squirting onto the ground for a leak.
Old Oct 18, 2008 | 09:52 PM
Izero's Avatar
Izero
ill bet on that being the problem :-P b/c the sensor is in a funny place so when you are a little low on brake fluid and u accelerate the fluid sloshes away from the sensor which causes the brake light to go on
Old Oct 21, 2008 | 05:17 PM
Michelangelo
It was indeed low in the resevoir of brake fluid. No leaks to speak of; filled it up and problem was fixed.
Old Nov 19, 2008 | 08:28 AM
thatcmhguy's Avatar
thatcmhguy
Smile Brake light and "ding" from 1st gear
I had the same problem, started out of the blue. I read about adding brake fluid, but the real problem was the brakes were worn down.
I replaced the front brakes myself with Wagner Ceramics.
Apparently I did it right, cause I stop without the "Fred Flintstone" method.
