03 uses oil
Old Feb 8, 2005 | 11:35 PM
gilitar's Avatar
gilitar
Default 03 uses oil
I was wondering if anyone else is having a problem with their Neon using oil. Our 03 uses almost a quart between changes so I asked the service guy about it and he said that it was normal. So what do you guys think?
Old Feb 9, 2005 | 01:49 AM
dirtrider222's Avatar
dirtrider222
Default RE: 03 uses oil
i wish mine only used a quart between changes
Old Feb 9, 2005 | 01:51 AM
ewetho's Avatar
ewetho
You probably won't get anywhere with a dealer as far as the factory is concered it is not consuming oil until you exceed 1 qt per 1000 miles. Have you tried different weights or brands. Synthetic etc..???
Old Feb 9, 2005 | 03:24 AM
LowSlowNeon's Avatar
LowSlowNeon
Mine doesn't use too much up. In fact, its usually still right where it was when I put the oil in. I run mobil 1 synthetic 5W-30.
Old Feb 9, 2005 | 05:15 PM
casper's Avatar
casper
I would complain about it, I have a 98 with 150,000 miles and I barely burn a quart every 3000 miles.
