Speedometer and Tachometer went backwards
Old Dec 8, 2008 | 04:40 PM
MattFire141's Avatar
MattFire141
Default Speedometer and Tachometer went backwards
My battery went dead in my 04' Neon SXT when I was at work and I had security give me a jump with their battery jump start. When I got a jump, the speedometer and tachometer needles flipped around backwards and are now resting under the pins. Is there any way to reset this?
Old Dec 8, 2008 | 04:42 PM
carbuff105's Avatar
carbuff105
You should be able to reset the cluster by holding the trip/reset button down and then turning your key on.
Old Dec 9, 2008 | 01:47 AM
darthroush's Avatar
darthroush
Section Moderator
I believe the reset procedure is also in the owner's manual.
Old Dec 10, 2008 | 01:51 AM
InPsychOut's Avatar
InPsychOut
I'm sure I read this exact same post yesterday either on here or another forum. Whoever it was did the reset and it fixed it. Was that you?
Old Mar 6, 2016 | 12:07 AM
Allyourbase51's Avatar
Allyourbase51
Had the same problem (needles going backwards) while diagnosing starter issues in a 2003 Dodge Grand Caravan, holding the trip meter button, waiting for the display to reset, then keying the vehicle on turned the needles back the right way.
