Question on a timing belt replacement
Old Dec 24, 2008 | 10:26 PM
mcfisher1980's Avatar
mcfisher1980
Default Question on a timing belt replacement
i have a 04 neon sxt with 75k miles. im planning on getting the timing belt changed sometime within the next week or 2. while im at it i might as well get them to replace the water pump while they are right there at it. now since i work at autozone i can get the parts for next to nothing. my question is, i went to order the timing belt kit that with comes with the belt and tensioner but when i did, the computer gave me the option of ordering the mechanical or hydraulic tensioner kit. how would i tell which one my neon has, or i wont be able to know until the timing belt cover is off or would i just be better off getting both and sending the one i dont need back. thanks in advance
Old Dec 25, 2008 | 03:24 AM
contagious19's Avatar
contagious19
i think its mechanical for 00 or 01 and under 02 might b hydraulic but i might need to double check
Old Dec 25, 2008 | 12:49 PM
mcfisher1980
yea if you can find out, that would be helpful. if not, its no biggie. i would rather get both just in case and send the one i dont need back but thanks for the input so far
Old Dec 25, 2008 | 10:23 PM
contagious19
looks like 2004 is mechanical tensioner
Old Dec 25, 2008 | 11:17 PM
mcfisher1980
ok. thanks for the input
Old Dec 26, 2008 | 05:21 PM
fgee's Avatar
fgee
could be either or wont know till you get in there
