2003 trans slipping--need help
Old Feb 2, 2009 | 08:21 PM
tremple1's Avatar
tremple1
Default 2003 trans slipping--need help
This morning my 2003 dodge neon decided it was not going to move. I put it in reverse and it would not move until I revved it up. Same thing in drive. The trans fluid looks like it is at the right level and does not smell burnt. The car has 86,000 miles. I drove it all weekend with no problems. It has been very cold here the last two weeks but a little warmer this morning. Any ideas?
Old Mar 4, 2009 | 02:02 AM
neonftw87's Avatar
neonftw87
change the trans fluid and the filter... sometimes this is was causes it... if not, im sorry to say youll have to have it rebuilt or buy a new one.. i hope this helps you bro, gl
Old Mar 4, 2009 | 02:08 AM
darthroush's Avatar
darthroush
Section Moderator
Sounds sorta like what mine was starting to do (at about 83K for me). Does it make any noise out of curiosity? How and when are you checking the fluid? If no noise, I'd say go with the above and try a fluid change first. They are very picky about the quality of the oil.
Old Mar 4, 2009 | 02:19 AM
neonftw87's Avatar
neonftw87
lol i remember roushes problem, it was rough haha.. i think he got his taken care of tho.. i forgot to add, im not sure if you have to have a specific brand of fluid, i would check up on that also
Old Mar 4, 2009 | 04:06 PM
darthroush's Avatar
darthroush
Section Moderator
NAPA ATF+4 is relabled Valvoline for $1 cheaper a quart. Cheapest I found and is certified by Dodge.
Old Mar 5, 2009 | 08:05 AM
N3ON's Avatar
N3ON
yup.when it was really cold here mine did the same.you have to let it warm up.i would also change the filter and fluid when you can.
Old Mar 5, 2009 | 09:32 PM
NeonOn19s's Avatar
NeonOn19s
just pull it out and replace it with a MTX...... you will be happier.. LOL
J/k j/k
I would check the fluid first there might be a clog some where, and when you rev, you build up pressure.
