what can i do to get more power out of my wifes neon?
Old Feb 9, 2009 | 02:15 AM
Adionik's Avatar
Adionik
Don't waste a dollar on an intake, they don't do anything. TB, UDP and possibly header (Short tube) are going to be easy and show the most gains
Old Feb 9, 2009 | 09:26 AM
gcrn7081's Avatar
gcrn7081
I respectfully disagree. K&N is dyno proven and guaranteed.
Old Feb 9, 2009 | 10:46 AM
Kath's Avatar
Kath
airflow improvements like a CAI are a bit overrated, on the dyno they pick the one spot where there is the largest difference between the two, and say 'gee golly look at that! 8hp!, when in reality the average difference across these jagged graphs is more like 2 hp, with maybe an average gain in the 5000-6500rpm range of say 3-4hp. But it does help, just don't go adding up the advertised performance gains and start thinking that you can make 30hp with nothing but intake & exhaust tubing. Those parts might make that much difference... but only ON a turbocharged car, or with a racing cam, or with both), basically you'd need to do something to the engine which would make it benefit from a much more volumous airflow to get 'significant' gains. but on a stock engine there is a limit to how much hp you can squeeze out of wider airflow alone. basically if there is no appreciable restriction to airflow in and out of your engine, then that's all, nothing wider will do anything for ya (but it will sound better still ).
Old Feb 10, 2009 | 03:16 AM
gcrn7081's Avatar
gcrn7081
I have person experience on quads. I can take a stock air filter and put "X" main jet in and then put a K&N filter and put "X" jet in and then go even higher with a uni filter with "X" jet. Each time a noticeable power gain. So, making it breath better does help. I have also, raise the rpm on the with a stock box, then an aftermarket filter and it revs much cleaner and higher. Besides, have you seen the big box under the hood and under the fender? Yikes!
It's a 2.0l so every ponny helps. I understand. I do. It's not like my old F250 diesel where a $299 chip now makes me 400hp/700tq But, if you do a few things, you will notice. It all depends on how much your wanting to spend.
Think of a motor like a pump. More air/fuel in and out the faster you go. On the neon, if I can gain 20hp from an intake, exhaust, and 60mm throttle body and some MSD ignition I am good
Old Feb 10, 2009 | 10:39 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
kath, you are correct when saying dyno... the manufactiors of the products say say hp messured by the crank and not the wheels... some good manufactors will often give u both, wheel and crank hp rating, but not many...
Old Feb 10, 2009 | 10:41 AM
dtjackten's Avatar
dtjackten
and i make 300 more whp i am happy..... HAHA, lol
Old Feb 10, 2009 | 05:31 PM
INVUJerry's Avatar
INVUJerry
without getting too deep into the car... a CAI, 55mm throttle body, header, cat-back, & underdrive pulley, should get you about 10% more power. AND give you better gas mileage. These parts would just let the engine breath better, and decrease the amount of power drain that your accessories draw from the engine. While the effects should be positive throughout the operating range of the engine, the bulk of your power gains will be realized at higher rpm where airflow becomes more significant.
After that an R/T or crane cam (& springs) will get you less throttle response at the low end, but great high rpm power. This will take away any gains in gas mileage you got from the other parts. I would imagine, that with a cam (combined with the above listed mods) could maybe get the engine to about 15% or more gain over stock power. Racing cams don't really give you more power on the rising side of your torque curve, they just extend the peak into a higher rpm range, so that your engine can rev higher before peaking out, but at the cost of degrading your low rpm efficiency and giving you a less smooth idle.
I can see a 10% increase at first, but with the NGC controller (the 03-05 computers) you'll dwindle back down to a near-stock level with the way the computer controls the fuel trims. Sure, you can't really stop the flow of air through the car, but you aren't going to get huge gains with the computer mixed with the automatic transmission. The car is going to run a 17 second quarter mile regardless. The mag cam will give a definate increase in power, and you will sacrifice nothing on the low end. Just the perceived "OMG it pulls harder up top" makes the low end feel less. I put a huge cam in my stock bottom end 98, and after 5500 it really comes alive, but it's still better than stock on the low end.
Old Feb 11, 2009 | 02:03 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Get a replacement cylinder head from the yard, and port match it on the intake and exhaust side. A better cam (95 cam is cheapest) would fair well with the smoother air flow. Ebay have very fair priced headers and underdrive pulley. A cai would be a nice addition, and can be made for next to nothing. Research is your friend. Top that off with a tuning device (SAFC II or NEO) as the factory PCM runs you rather rich. Oh, and 5sp neons run circles around n/a autos. Truth.
If I could do it again, I'd start with port matching and tuning. Work from the inside out.
Old Feb 11, 2009 | 03:07 AM
neonftw87's Avatar
neonftw87
Originally Posted by spec_ops57
Chipping the car is vurtually (won't let me correct spelling) useless given the programming on the Neons computer.
If you want a decent increase in power, you'd probably have to go with building up your internals and forced induction.. But that's probably a little out of your wife's league.
Stick with the cold air intake, free flow exhaust, maybe a bigger throttle body
smartest answer in this whole post bro, listen to this.. you dont wanna build it up to where your wife cant handle it, but this should be good enough for you to feel a difference and for her to be able to drive it... Dont listen to these douchebags that just wanna give you **** cause they are still kids.. just like this guy said tho... intake, exhaust, and throttle body
Old Feb 12, 2009 | 06:08 PM
INVUJerry's Avatar
INVUJerry
I really hope you're not saying I'm only trying to give **** and not help, and I really hope you're not calling me a kid. I've been down the "Mod the NGC" road before. Intake and exhaust will help, but the most you'll feel is what they call "the butt dyno" . A louder car feels like a faster car.
BTW, the Jet chip (the only chip they have right now for the 03-05 neons) dosen't do anything, it's been dyno proven tha tit dosen't give any gains what so ever.
