LED lights
ok so i know our cluster lights are like a 194 right???so i went to autozone and got some regular blue lights and they dont look that great.so those of you that did a led cluster i have questions for.
-where did you get em at?
-will they fit without having to mod the cluster?
thanks guys,
thanks guys,
http://autolumination.com/194.htm
get some wide bulbs and you should be good to go with no modification.
They start at 2.99 each, at AL they cost 6.99.
www.byvampdesign.com
thats what i have in mine and yako used to have in his
First off what color is the stock cluster ??? Dodge uses the cluster itself to "tint" the clear bulbs ... if you put blue bulbs behind the tint still effects it ... you have to sand the tint off to get the pure blue color
You only have to get the film off when you do colors other than green, blue and white.
