what can i do to my dodge neon se to make it faster
same thing here i have the same car but its a 3spd no over drive automatic can i do a engine swap to a srt4 and still be ok or will i have to do the trans also, i mean i have a company truck for work and a bike for summer i built so car is for fun and i just ordered a nice *** bodykit duraflex viper.
thanks
paul
thanks
paul
this is a basic list of what u would need from the srt-4
also it would probably cost around $5000 to do it correct.
and for the 01 automatic neon im sure itll bolt up with a little slight mod with the motor/engine mounts and not going to get technical rite now but also the shifter *** and everything would have to be changed (because its a 5 speed durr.lol)
Engine and Tranny (duh)
Complete Engine Wiring Harness
Complete Engine Bay Wiring Harness
Power Steering Pump, lines, and cooler
Clutch master and slave cylinder
Clutch/Brake Pedal assembly
Intercooler Piping
Intercooler
Radiator Hoses
Lower Motor Mounts (the hole in the lower mount is larger for larger bolts)
SRT PCM (wont' need the bracket if swapping into an 03+)
Axles (and half shaft if it isn't on the engine)
Coolant Bottle
Fuel Line from tank to engine bay
Fuel Pump
Flex Fuel line from solid fuel line to fuel rail
Short evap hose that comes from the purge valve
All vacuum lines and the 3 selonids
o2 Sensors
Turbo Housing + o2 Housing
Lower Control Arms (they're stronger yet the same in shape)
If you plan on using the front brake setup you'll need the following
SRT Power steering rack (it's shorter)
Knuckles
Flexiable Brake Lines
Calipers
Rotors
Intercooler Piping
Intercooler
Radiator Hoses
Coolant Bottle
Fuel Pump
o2 Sensors
Knuckles
Calipers
Rotors
and dam that sucks that u cant do the swap either. state laws suck sometimes. i mean dam its ur car u should be able to mod it anyway that u want too as long as its still street legal. ( now im talking engine and stuff like horsepower wise not lowering it being illegal and what not. )
dam ive never had to do an emissions test but that would suck if they had them here in indiana.
I was gonna say dt i gots someone in ny i could have slap a sticker on it if you want to swap to a 2.4 lmao. I was talking to one of my buddies and i remembered the Ram 50 or in other names the Mighty Max(mistsu) Uses the 2.0 and five speed rear wheel drive. How about you dt taking the trans and rear end drop into your neon so that it's a 400 whp at the rear
