Tuner Lugs?
Old Feb 20, 2009 | 11:32 AM
redbirdhky6's Avatar
redbirdhky6
Default Tuner Lugs?
Ok so I have a set of Motegi mr8s that are away getting powdercoated right now. I never checked to see if I needed different lugs before I took them to the shop. I've tried searching and finding some specs on them but I havent had any luck. So can anyone help me, do I need tuner lugs with motegi mr8s?
Old Feb 20, 2009 | 11:33 AM
redbirdhky6
i just would like to know so I can order them this weekend if I need them
Old Feb 20, 2009 | 11:38 AM
NeonOn19s's Avatar
NeonOn19s
umm... any lug nuts should work, I bought light weight lugs that are narrower so then I don't scratch up my rims. You can go to any specality rim store online and match what they recommend for that rim. The only ones that I wouldn't recommend are the open ended one, due to they will rust quicker.
Old Feb 20, 2009 | 02:46 PM
redbirdhky6
well they are discontinued so I cant find anyone that carries them or has specs on them.
darthroush's Avatar
darthroush
Section Moderator
Call Motegi's CS number and ask 'em. They should be able to tell you.
Old Feb 20, 2009 | 04:19 PM
OhNo2.0's Avatar
OhNo2.0
Also pay attention to your stud length...You never want to just bite into 3 or 4 threads. If they are too short studs are cheap and easy to change out.
