Headlight Help
Old Feb 25, 2009 | 06:47 PM
irishking's Avatar
irishking
Default Headlight Help
Okay guys, I have projector headlights. They use H1 bulbs. Factory wiring that is plug into headlights are for 9007. I guess i am saying this correctly. Not sure. I wanna get an HID kit but dont know what to do. I wanna keep my projectors but get an HID kit. Do i get 9007 HID Kit or H1 HID Kit.
Old Feb 25, 2009 | 06:51 PM
irishking's Avatar
irishking
Exclamation Rear Bumper
I am going to be installing a SRT-4 Rear Bumper to my 2000 Dodge neon. Has anyone installed a rear bumper. Can anyone give some advise on how hard or easy it is to install.
Old Feb 25, 2009 | 09:56 PM
NeonOn19s's Avatar
NeonOn19s
www.vvme.com for the hid kit, and you will need a H1 kit. then you would hook it up. it will have an adapter to connect to your OEM line.
the install will be easy, it still uses the existing bolt up as your 00 rear. You will have to swap out your tail lights to the 03 or higher style. The bulbs and mounts will be the same.
Old Feb 26, 2009 | 11:02 AM
00Neon RCR's Avatar
00Neon RCR
just think man. unless the 9007 bulbs will also mount into the lights you need the H1 kit. and vvme.com is EXCELLENT for HID kits, comes with everything you need, no cutting or splicing or anything like that just plug-n-play. they have every temperature you can think of. even comes with a 14 month warranty (not much but hey better than nothing.) also remember if you want to still have both high and low beams you are going to need either a single beam xenon with a relay or a double beam xenon with a relay. the difference between single and double beam is meaning (double beam are HID's on 4 bulb lighting systems if im not mistaking) last time i check they were 40.99 USD for the kits, (plus shipping and handling)
Adam
p.s someone correct me if im wrong on the double beam xenon statement. thanks.
Old Feb 26, 2009 | 11:20 AM
N3ON's Avatar
N3ON
yo buddy whats up.well the bumper will be easy but about the lights.ebay has them also and thats where i got mine.they were $84.99 w/ free shipping and the value of them is respectable.H1 all the way!!!
Old Feb 26, 2009 | 09:35 PM
srtgtr34's Avatar
srtgtr34
You need an H1 hid kit for the lights and for the relay you have to buy a 9007 relay Harness, Try retrosolutions.com and retofitsource.com, for the harness
Old Feb 27, 2009 | 10:07 PM
irishking's Avatar
irishking
thanks guys.. i got the bumper n waiting for tail lights ant wait mad excited.
