Engine/tranny swap
Old Mar 2, 2009 | 07:25 PM
OhNo2.0's Avatar
OhNo2.0
I'm gonna have to pull it out the top cause whoever curbed the donor car curbed it good. the whole crossmember/rad mount is pushed back about 5 inches at the bottom.
Old Mar 3, 2009 | 12:19 AM
darthroush's Avatar
darthroush
Section Moderator
Use a torch if you aren't using those parts?
Old Mar 3, 2009 | 01:14 AM
Izero's Avatar
Izero
yea just cut that crap right the hell off... i just hope that that kinda hit didn't mess up the timing belt or any of the cam gears or anything... b/c then ur gonna have an expensive repair for that motor.... :-P definate pain in the *** for sureeeee
Old Mar 3, 2009 | 07:40 PM
OhNo2.0's Avatar
OhNo2.0
Drove the car home when I bought it.
Old Mar 4, 2009 | 02:53 AM
neonftw87's Avatar
neonftw87
easiest way ive found to pull the motors outta neons..
they are made to come out of the bottom, you can tell by the passneger mount that it attached to the frame rail
take your axles out, unbolt the sub frame from the body, unbolt your mounts, unplug the wiring fromt he computer, take off your clutch, shifter, and throttle cables, and take the spindles off your struts, take the pin out of the steering linkage, then jack the car up, the engine, subframe, front wheels and all will fall out,
Old Mar 4, 2009 | 02:58 AM
neonftw87's Avatar
neonftw87
im just warning you bro, pulling out the top will be a bitch, the mounts will give you hell, the mount that it on the timing belt case will bust the timing belt case, not to mention there are no pulling points... trust us man, cut out the parts you have to replace anyways, and drop it out the bottom, its not worth damaging anything else on the engine.. if there were pulling points it wouldnt make a differnce, but the only place youll be able to pull is from the intake, which is plastic, and will break... ive dont it man... dont try it.
Old Mar 4, 2009 | 08:15 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
Hey, ohno2.0 u got a battery tray out of that parts car???? very interested if so!!! pm me if u do, and how much u want for it... as long as the mount bolt is not stripped i will take it... thanks
Old Mar 4, 2009 | 01:21 PM
neonftw87's Avatar
neonftw87
i gotta go to the garage today and put my motor back in today lol, i just may have a battery tray, ill look and if so ill let you know, hell ill just give it to you, but lemme make sure i got one first
Old Mar 4, 2009 | 03:29 PM
dtjackten's Avatar
dtjackten
Cool, let me know.. i need one bad... and it is out right now, but i will need it soon... dont have time to go to the junk yard and get it because i dont get out of work till all of them close around me....
Old Mar 19, 2009 | 01:33 AM
neonftw87's Avatar
neonftw87
bro i searched everywhere, pop musta hauled it for scrap lol, he hates all my old **** laying in piles lol, cant really blame him to be honest.. but accually to be honest the tray that i had came from a 96 so i dont htink i would have fit yours anyways.. im sorry man
