Lights Not Working NEED HELP QUICK!!
Old Mar 9, 2009 | 10:49 PM
one_disturbed_person's Avatar
Default Lights Not Working NEED HELP QUICK!!
Hello.
I have halo projector headlights and I realised my halos werent working sao I took them off and re connected the wires and now they won't work at all. I then removed the headlights and decided to forget about the leds so I try to reconnect the wires to make just my parking lights work. I accidentally connected the ground wire to the hot wire (black wire to black with yellow line). As soon as I figured out what I did I removed them and reconnected them in the way they were supposed to go. Now they won't work at all and I am unsure of exactly what to do. My parking lights, instrument panel, and tail lights won't work. I need help quick as I close the pet store tommorrow that is an hour drive away. Thats an hour drive with no tail lamps. My headlights however do work. PLEASE HELP ME!!!!!!!
Thanks for all help!!
Daniel
Old Mar 9, 2009 | 10:58 PM
smallblockfreak's Avatar
smallblockfreak
You blew the fuse. When you open the driver side door next to the steering wheel open the little panel and replace the fuse that is blown.
Old Mar 9, 2009 | 11:08 PM
can you give me any clue as to which fuse it is? I see the little map on the inside of the door of the fusebox but I can't tell which fuse it is...
Daniel
Old Mar 9, 2009 | 11:28 PM
Nevermind I found it!! Thanks sooooooo much!!
Daniel
Old Mar 10, 2009 | 11:01 AM
smallblockfreak
your welcome
