New Headlights!
Old Mar 18, 2009 | 01:54 PM
srt4rez's Avatar
srt4rez
I got mines upgraded through Autolumination. They got the H-1's in different lightenings. That is the size that they come with, if stock. You can order theirs, if you want to upgrade too. All depends what you want.
Old Mar 18, 2009 | 03:37 PM
NeonOn19s's Avatar
NeonOn19s
Originally Posted by N3ON
the only bad thing about the halos is like with me.i have an hid kit for 9007.i would have to change my bulb size
That is what I had to do. I located a company that sold my existing kit and bought the H1 bulbs to fit the projectors and the kit. cost a bit, but then I have a back up of bulbs and lamps if anything happens.
Old Mar 18, 2009 | 08:53 PM
pryankee's Avatar
pryankee
I got a question for you. Did you had to modive the projector socket in ny way to fot the bulb? And after you installed the hid can you use both low and hi beams?
Old Mar 18, 2009 | 10:19 PM
OhNo2.0's Avatar
OhNo2.0
I think I'm going to install some bright a$$ HIDs in place of the fog light holes in my bumper. The only time I would use them(and on high, pointed high)is when another moron with hids drives by.
Sorry guys but I think the idea of YOU being able to see better then everyone else yet burning their retinas at the same time...is complete bu||$hit. I have literally been temporarily blinded MULTIPLE times due to idiots with ULTRA SUPER BRIGHT HIDS. And the next F aggo t that almost causes me to get in an accident is going to have his/hers HIDS shoved where the sun don't shine...after I smash them into little sharp peices with their face.
/rant
Old Mar 18, 2009 | 10:26 PM
OhNo2.0's Avatar
OhNo2.0
NHTSA Cracks Down on Aftermarket HID Conversion Kits
The National Highway Traffic Safety Administration (NHTSA) is targeting high-intensity discharge (HID) conversion kits for enforcement actions. NHTSA has concluded that it is impossible to produce HID conversion kits (converting a halogen system to HID) that would be compliant with the federal lighting standard, Federal Motor Vehicle Safety Standard (FMVSS) No. 108. The noncompliant kits frequently include a HID bulb, a ballast, an igniter, a relay and wiring harness adapters. The NHTSA believes this equipment presents a safety risk to the public since the kits can be expected to produce excessive glare to oncoming motorists. In one investigation, the NHTSA found that an HID conversion headlamp exceeded the maximum allowable candlepower by over 800%.
Under FMVSS No. 108 Section S7.7 (replaceable light sources), each replaceable light source for headlamps must be designed to conform to the dimensions and electrical specifications for the headlamp source it is intended to replace. For example, if an HID kit is marketed as replacing an H1 light source, then it must match the H1's wire coil filament size and location, the electrical connector size and location and the ballast design for use with an H1 light source (which is impossible since there is no ballast). Consequently, companies that are manufacturing HID light sources (e.g., D1S, D1R, D2S, D2R, 9500, etc�) with incandescent light source bases (e.g., H1, H3, H7, H8, H9, H11, H13, HB1, HB2, HB3, HB4, HB5, etc�) should be aware that this light source design would not be one that conforms to FMVSS No. 108, and could not be imported and sold in the United States without violating Federal law. (The importer is treated as the manufacturer and subject to the same fines and penalties that apply to a domestic manufacturer.)
NHTSA has also determined that a commonly used disclaimer "for off-road use only" has no legal meaning and is not recognized by the agency as the manufacturer, importer and retailer are not in a position to control use once a product has been sold. Any equipment offered for sale which is covered by FMVSS No. 108 (headlamps, taillamps, side markers, etc.) must comply with the standard.
I hope you all get tickets.
Old Mar 18, 2009 | 11:04 PM
pryankee's Avatar
pryankee
I understand all of that!! and I agree with you in some way! I hate when people put hid's on the sock reflector...I think u have to use them the right way in this case with the proper projector...the dont have to be the best one but at least you eliminating some big % of the glare produced by the reflector.... But you cant give people ticket's for havin hid's on the cars cuz the higher end cars come stock with hid....
Old Mar 19, 2009 | 07:28 AM
N3ON's Avatar
N3ON
HA HA HA I FAIL!!!!!
i know mine aren't 100 percent safe
Old Mar 19, 2009 | 08:55 AM
OhNo2.0's Avatar
OhNo2.0
This isn't a shot at you guys, it's at the lights. Just a certain pet peeve of mine. If I seen a NEON with HIDS...I'd probably go easy on the driver and insert the light where the light don't shine in one piece instead of a thousand little sharp pieces.
Old Mar 19, 2009 | 10:47 AM
N3ON's Avatar
N3ON
ha ha ha.that took me a while to get.lol.i think in the state of OH you have to have lower then 10,000K to run em in halogen housings.but i live in KY
Old Mar 19, 2009 | 01:43 PM
pryankee's Avatar
pryankee
here in PR it depeds on the cop....if they don't like themthey will give u a ticket. But theres no specific law against them
