Time to replace Timing Belt
Old Mar 20, 2009 | 11:16 AM
one_disturbed_person's Avatar
Default Time to replace Timing Belt
Okay I need to know what all I need to replace the timing belt. I know that I need a timing belt and water pump but is there any other supplies needed? I have almost 150,000 miles on my 2001 SE. It is automatic (not sure that it really matters). I know that it is supposed to get replaced at 105,000 miles so it is starting to scare me a little...
Daniel
Is this a good timing belt?
http://cgi.ebay.com/ebaymotors/1995-...Q5fAccessories
And what about this water pump?
http://cgi.ebay.com/ebaymotors/New-W...Q5fAccessories
Thanks,
Daniel
Old Mar 20, 2009 | 11:49 AM
neonftw87's Avatar
neonftw87
timing belt, water pump, when you got the engine dropped on down to where you can take it apart check your timing belt tensioner and the idler pulley that the timing belt runs on... for some reason the frame that my tensioner ran on broke in half but other than that i dont think you need anything, and the links you sent look fine... just make sure you set the time right again haha or you stuck in the problem like me.
neonftw87's Avatar
neonftw87
the frame for the idler... not the tentioner..* lol
Old Mar 20, 2009 | 11:56 AM
N3ON's Avatar
N3ON
bro i wish you luck.you mess up this project just a tad bit and you could fry your car.my buddie blew 3 cylinders cause his belt slipped.
Old Mar 23, 2009 | 01:14 AM
neonftw87's Avatar
neonftw87
i think i was lucky, i think my belt is just stretched a tad bit... not enough to bend valves and bust pistons, but enough to make it run like ****. but yeah, just make sure you get the timing dead on cause just like N3ON said... you can blow your cylinders if your off.
