hey guys im new but i need some help. i would be ungodly greatful.
sup yall im from idaho im rollin a 04 neon rt. i love my car and im guna drop a ton of **** into it. problem is i bought it cheap and its got some problems, when i gas it all it does is go like normal for a second lose power then gain power then lose it again... gooooooo put put gooooo put put. (sound effects make it more emotional) any clues???????
Welcome to DF lusky! Ill move this over to the Neon Section! Those guys and gals should be alble to help ya figure it out! Good luck and have fun on the site!
i would also run your fuel tank down all the way and then fill up with premium once and throw a bottle of fuel injector cleaner in there. the premium is because it also has more solvents in it to clean injectors which will add to the effect of the actual bottle of cleaner...good luck!
kk ran a quick check on the engine light and came back as a p0340 cam shaft position sensor circut mal. ima work on hat but ty for all the help guys. any more help would be great.
