tranny issue
Old Apr 21, 2009 | 12:12 AM
nhood21's Avatar
nhood21
Default tranny issue
i was riding along in my 03 neon and it did a surge thing (jerked forward) twice and the cel came on and it popped up a p 0700 and the car went into limp mode i had 1st gear, i think 2nd, and reverse. so is this the speed sensor? if so where is it located so i can fix it? Thanks a million.
Old Apr 21, 2009 | 03:53 PM
nhood21's Avatar
nhood21
anyone?
Old Apr 21, 2009 | 04:39 PM
darthroush's Avatar
darthroush
Section Moderator
This is what I show for the code? Not a speed sensor, unless there is another code?
P0700-TRANSMISSION CONTROL SYSTEM/READ TRANSMISSION
DTCS ON THE DRBIIIt
1 This is an informational DTC letting you know that a DTC(s) is stored in the
Transmission Control Module.
Erase this DTC from the PCM after all Transmission DTC(s) have been repaired.
Using the DRBIIIt, read the Transmission Controller DTC and refer to the
Transmission Category and perform the appropriate symptom.
Anyways...
DESCRIPTION
VEHICLE SPEED SENSOR
The Vehicle Speed Sensor (VSS) is a pulse generator
mounted to an adapter near the transmission output
shaft. The sensor is driven through the adapter
by a speedometer pinion gear. The VSS pulse signal
to the speedometer/odometer is monitored by the
PCM speed control circuitry to determine vehicle
speed and to maintain speed control set speed.
REMOVAL
(1) Raise vehicle on hoist.
(2) Disconnect the speed sensor connector (Fig.
149).
CAUTION: Clean area around speed sensor before
removing to prevent dirt from entering the transaxle
during speed sensor removal.
(3) Remove speed sensor retaining bolt (Fig. 149).
(4) Remove speed sensor from transaxle.
CAUTION: Carefully remove vehicle speed sensor
so that sensor drive gear does not fall into transaxle.
Should sensor drive gear fall into the transaxle
during sensor removal, drive gear must be
reattached to sensor.
(5) Remove speed sensor drive gear from speed
sensor.
INSTALLATION
(1) Install pinion gear to speed sensor (Fig. 149).
(2) Using a NEW o-ring, install the speed sensor
to the transaxle (Fig. 149).
(3) Install the bolt and torque to 7 N·m (60 in.
lbs.).
(4) Connect speed sensor connector (Fig. 149).
(5) Lower vehicle and road test to verify proper
speedometer operation.
Old Apr 21, 2009 | 05:17 PM
nhood21's Avatar
nhood21
so do you think im in for a tranny rebuild or replacement?
Old Apr 21, 2009 | 10:04 PM
OhNo2.0's Avatar
OhNo2.0
That's only 2 steps harder then changing a friggin light bulb. Can you change a light bulb?
Old Apr 22, 2009 | 12:55 AM
darthroush's Avatar
darthroush
Section Moderator
For a speed sensor, if that's what that is? Neither...
Just seems the P0700 code means there are more codes stored. What did you use to get the P0700 code? Scanner? Gauge cluster?
Old Apr 22, 2009 | 01:05 AM
nhood21's Avatar
nhood21
both, i went to zone and did the key thing and iv been researching the heck out of it and it seems to point to trans control modular, but im wondering if the whole thing needs replaced, im not sure. there are more codes but i have to find them, ihave them written down somewhere. Will the gauge cluster tell you all the codes or just a few of them?
Old Apr 22, 2009 | 02:12 PM
darthroush's Avatar
darthroush
Section Moderator
I'm not sure of that one. I use an OBDII scanner. I'm sure someone else would know.
Old Apr 22, 2009 | 03:21 PM
nhood21's Avatar
nhood21
ok im sure iv got all the codes. 0700 trans control system, 0440 evap emission control (gas cap)? 0755 shift solenoid b malfunction, and 0344 CPS.
Old Apr 22, 2009 | 06:48 PM
darthroush's Avatar
darthroush
Section Moderator
I can't find the P0755 in the manual, but just looking at the name. I'd think that is the problem with the transmission. If the solenoid doesn't work, neither will the transmission.
You may check these links though: https://dodgeforum.com/forum/dodge-c...731-p0733.html
http://www.justanswer.com/questions/...place-solenoid
http://www.justanswer.com/questions/...eon-wont-shift
This says it only applies to 04's, but I suppose checking the date wouldn't hurt: http://dodgeram.info/tsb/2004/21-001-04.htm
My 03 needs to have the TSB done for the PCM as well, just don't have the $100 to pay for the programming to do so.
P0344-CAMSHAFT POSITION SENSOR INTERMITTENT
When Monitored: Engine running or Cranking.
Set Condition: When the failure counter reaches 20. One Trip Fault.
POSSIBLE CAUSES
GOOD TRIP EQUAL TO ZERO
WIRING HARNESS INSPECTION
(K7) 5 VOLT SUPPLY CIRCUIT OPEN OR SHORTED TO GROUND
TONE WHEEL/PULSE RING INSPECTION
CHECKING CKP SIGNAL WITH THE DRBIIIt LAB
(K44) CMP SIGNAL CIRCUIT OPEN
(K44) CMP SIGNAL CIRCUIT SHORT TO GROUND
(K44) CMP SIGNAL CIRCUIT SHORTED TO B+
(K44) CMP SIGNAL CIRCUIT SHORT TO (K7) 5 VOLTS
PCM
P0440-GENERAL EVAP SYSTEM FAILURE
When Monitored: Engine Running. Fuel Level greater than 12%. Ambient Temperature
between 4°C and 32°C (39°F and 89°F)
Set Condition: The PCM does not see the NVLD switch close during the medium/large
leak test. The PCM will then increase the vacuum supply to the EVAP system by
increasing flow through the EVAP Purge valve. If the switch does not close with an
increase in vacuum, an error is detected. Two Trip Fault.
POSSIBLE CAUSES
VISUAL AND PHYSICAL INSPECTION
EVAP PURGE SOLENOID VACUUM SUPPLY INSPECTION
EVAP PURGE SOLENOID STUCK CLOSED
NVLD SWITCH OPERATION
(Z1) GROUND CIRCUIT OPEN
NVLD ASSEMBLY
(K107) NVLD SWITCH SIGNAL CIRCUIT OPEN
EVAPORATIVE EMISSION LEAK DETECTION
PCM
PCM
