Idling / Overfueling problems
Old Apr 21, 2009 | 07:44 AM
ProNeon's Avatar
ProNeon
Unhappy Idling / Overfueling problems
Heya all,
Need advice please. I have a Neon 2001 2L 16V manual transmision.
Problems:
Irregular idling, huge loss of power, emitting black smoke [ unburned fuel ]
Have done so far:
Removed CAT
Checked coil
Changed plugs twice
Other info:
I get different answers from different Mechanics/Workshops:
- ecu faulty
- lamda sensors faulty
- crank sensor faulty
Previously I had the ecu reset via diagnostic tools, the car performed well for a month, then back to black smoke again. Went back to diagnostic place, did not get error code from ecu. This morning I tried the reset myself by removing car battery terminal for 10mins. The car is a lot better, but will gradually deteriorate over a period of 3 to 4 weeks.
It seems whatever the problem is, manifests itself over time after the ECU gets reset.
Any suggestions please?
Old Apr 21, 2009 | 10:35 AM
darthroush's Avatar
darthroush
Section Moderator
Well, the cat helps burn up a/f that isn't burned in the engine.
If you keep having to reset the computer, sounds to me like that could be the problem?
Old Apr 22, 2009 | 03:53 AM
neonftw87's Avatar
neonftw87
if resetting the computer is clearing it up for a few weeks, that does sound like the computer.... BUT could it also be that reseting the computer is clearing the codes, but yet after 3 to 4 weeks of running, the sensors are throwing codes again while the computer is trying to correct the problems it making it run like ****, then you reset it again? I couldnt really tell you about this, your prolly better off taking it to a dodge dealer... did you try running diagnostics on it with an OBDII or the key switch trick?
Old Apr 23, 2009 | 03:52 AM
ProNeon's Avatar
ProNeon
Not sure which type diagnostic equipment were/are used. Had it to Bosch once, they advised LAMDA sensors. Key switch trick?.. please elaborate.
Old Apr 23, 2009 | 07:08 AM
jagass's Avatar
jagass
Whoa...Too many sucking problems...lol
Old Apr 23, 2009 | 02:07 PM
neonftw87's Avatar
neonftw87
turn the key on and off 2 times then hold the trip button and turn it on and leave it on, your gauges will jump in quarters and it will start showing you codes.... *if there are in codes to show of course* i truly dont think the computer is the problem cause it will run fine if you reset it, i think its some bad sensors.
Old Apr 24, 2009 | 08:29 AM
ProNeon's Avatar
ProNeon
Thanks for the replies, it helps. My gut also tells me it is bad sensors, I am sure the ECU does constant correcting and at some point the RAM gets full.
Will try the key trick.
I will start with the LAMDA sensors and work from there on.
