04 neon spark plug question??
Old Jun 26, 2009 | 09:47 PM
jeffdodge0487's Avatar
jeffdodge0487
Question 04 neon spark plug question??
hey guys i got a quick question. I was browsing Modern Performance.com and I would like to buy the NGK Iridium spark plugs with colder spark. The website states that the stock NGK plugs work best on bone stock engines, and the colder plugs works on the modified engines. Just wondering which ones i should get. My engine is semi modified with a 60mm tb, cai, and full exhaust. Also can i use any spark plug wire company with my MSD coil pack? I would like to use the Granatelli wires with the MSD coil pack. please help me if you can.
Old Jun 27, 2009 | 01:12 AM
darthroush's Avatar
darthroush
Section Moderator
I'd go with stock plugs. No need for those wires or coil pack either, but your call.
Old Jun 27, 2009 | 07:36 PM
AnthemBassMan's Avatar
AnthemBassMan
-I'm kind of new to the Neons and other modern 4 bangers, but I also say stick with the stock plugs. I'm a lot more old school, and until you do something with the cam and up the compression, the stock plugs should suit you just fine. I have NGK V Powers in mine for almost two years now and I've had no issues what-so-ever. Plus you can get all four NGK plugs for about $6.
L8R,
Matt
Old Jun 29, 2009 | 11:58 AM
guppy's Avatar
guppy
iridium plugs at stock heat rang are awsome
Old Jul 4, 2009 | 02:44 PM
Moparmatt440's Avatar
Moparmatt440
x2^ that what I had in my sxt, my SRT I have two step colder. If you go with the iridiums be careful when gapping, that fine tip breaks easy. If you want to do wires its up to you, stock are okay, I had Magnacores, not to bad and granetellis, best near 0 ohms resistance, better then MSD, which are really good as well
