Motor mounts going wrong...
Old Jul 4, 2009 | 10:31 AM
oclife22's Avatar
oclife22
Default Motor mounts going wrong...
Okay,
I can feel my motor mounts going wrong. CAuse when im idle at a red light I can feel a vibration. My mecanic told me that for now it's not so dangerous...
But I CAN FEEL IT very hard....So Ill change it my self... People says it is eeasy... so yeah! im ready! :P
But should I just put some Inserts or get new mounts? Because I checked my mounts are still good , they solid... it's just the inside ( the black rubber).....
So if I install inserts ...will the vibration be gone??
Thank you everyone!!
Old Jul 5, 2009 | 12:16 PM
Ghost Neon 2's Avatar
Ghost Neon 2
If your stock mounts are bad, it is a good idea to replace them, before installing mount inserts. The rubber in the mounts are worn. There is no reason to put inserts in on poor rubber. Buy new mounts and use inserts or M window urethane and make them solid yourself.
Old Jul 5, 2009 | 01:17 PM
darthroush's Avatar
darthroush
Section Moderator
If you have bad mounts and put inserts in, you will double the amount of vibration you have now.
Old Jul 6, 2009 | 10:40 AM
oclife22's Avatar
oclife22
Does anyone know where I could find motor mounts for my dodge neon sx 2004 . Where they can ship to Canada???
Oh, and can anyone tell me what is the size of the bolts???
Thanks!
Old Jul 8, 2009 | 02:40 PM
OhNo2.0's Avatar
OhNo2.0
Just use original bolts.
And they can be found anywhere, from Parts Source to Ebay.
