sqeeky suspension
Old Jul 10, 2009 | 12:02 PM
rickyrod33's Avatar
rickyrod33
Default sqeeky suspension
when i drive i somtimes hear my suspenssion sqeeking how can i fix this is it pricey? i got 90,000 miles on my car is it worth fixing i also got a transmission problem... when i drive from first to second my transmission jumps i tried driving it easy for a while it seemed to make a little bit of a difference... it still jumps though... any advice??
Old Jul 10, 2009 | 12:40 PM
darthroush's Avatar
darthroush
Section Moderator
For the squeaking, you may check the lower control arm bushings. They seem to go out fairly often on these cars, especially when the mileage gets up there.
For the transmission, you should check your motor mounts and your transmission mount.
