cam sensor
Old Jul 28, 2009 | 08:33 PM
scotty_2.0's Avatar
scotty_2.0
Default cam sensor
i have a 04 neon 2.0 single cam. can anyone help me with info on replacing it? on like what i have to do.
Old Jul 29, 2009 | 01:15 AM
darthroush's Avatar
darthroush
Section Moderator
Simply put, you undo the connector and two screws/bolts, and reverse for installation.
Old Jul 29, 2009 | 04:54 PM
scotty_2.0's Avatar
scotty_2.0
thanks bro. when your looking at the motor from the front the sensor is on the right right?
Old Jul 29, 2009 | 05:29 PM
darthroush's Avatar
darthroush
Section Moderator
I'm on my laptop. I'll get on the desktop in a bit which has the manuals and double check.
Old Jul 29, 2009 | 07:50 PM
scotty_2.0's Avatar
scotty_2.0
dude thanks do much.
Old Jul 30, 2009 | 04:11 AM
darthroush's Avatar
darthroush
Section Moderator
If you are looking at the engine from the front of the car, it should be on the right side of the head.
REMOVAL - 2.0L
The camshaft position sensor is mounted to the
rear of the cylinder head (Fig. 9).
(1) Remove brake booster hose and electrical connector
from holders on end of cylinder head cover
and reposition.
(2) Disconnect electrical connectors from camshaft
position sensor.
(3) Remove camshaft position sensor mounting
screws. Remove sensor.
(4) Loosen screw attaching target magnet to rear
of camshaft (Fig. 10).
INSTALLATION - 2.0L
The target magnet has two locating dowels that fit
into machined locating holes in end of the camshaft.
(1) Install target magnet in end of camshaft.
Tighten mounting screw to 3.4 N·m (30 in. lbs.)
torque. Over torquing could cause cracks in magnet.
If magnet cracks replace it.
(2) Install camshaft position sensor. Tighten sensor
mounting screws to 9 N·m (80 in. lbs.) torque.
(3) Place brake booster hose and electrical harness
in holders on end of valve cover.
(4) Attach electrical connectors to camshaft position
sensor.
