2000 dodge neon wont shut off
Old Aug 11, 2009 | 09:10 AM
bvfd_434's Avatar
bvfd_434
Exclamation 2000 dodge neon wont shut off
2000 Dodge neon
2.0 SOHC
195,000 miles
Starts just fine and runs. the problem is when you shut it off and remove the key from the ignition, all electrical componets shut off but the motor stays running and the IC stays on. The only way to get it to shut off is to dump the clutch or disconnect the battery cables.
Replaced the ingition switch and lock and cylinder, same results, no change. and just replaced the automatic shut off relay. no change there either
Anyone with some suggestions??????
Old Aug 11, 2009 | 03:53 PM
srtgtr34's Avatar
srtgtr34
Thats really weird... Check your relays under the dash and all your fuses.
Old Aug 11, 2009 | 04:15 PM
bvfd_434's Avatar
bvfd_434
thanks for replying, everything seems to be good in that area, its mind blowing. cant quite pinpoint it
Old Aug 12, 2009 | 07:52 PM
DESIREESAVENGER's Avatar
DESIREESAVENGER
Try replacing the fuel pump relay
Old Aug 12, 2009 | 08:31 PM
dakota26's Avatar
dakota26
ignition switch bad
