GRRRRRRRRRRR.........throwin engine codes
Old Mar 27, 2005 | 05:43 AM
LowSlowNeon's Avatar
LowSlowNeon
Default GRRRRRRRRRRR.........throwin engine codes
Dammit. Well my turn signals quit working today for some reason. So I was tackling that problem....I happened to reset my pcm in the process and when I started my car up afterwards my check engine light was on. I pulled the codes and I get a P 0522, which is a oil pressure sender code. Hmmm.....I wonder why I'm getting that one? Any guesses? If not, take a look at my pictures of my guages. Anyways, is there anyway I can hook up to my car with a laptop and just turn the CEL off? I know why its on....its pointless, I already pulled the dummy oil light bulb since it was just being annoying. I know I could "T" it off and use both the stock sensor and my aftermarket pressure sender.....but I had a hard enough time getting the new pressure sender in there, let alone be able to T it off and use both. Grrrrrrrrrrrrrrrrrrrrr. I would just be satisfied if I could basically disable that one....the car feels like its actually running better now that the check engine light is on. LOL. At least I know its nothing to worry about.
Old Mar 27, 2005 | 05:58 AM
casper's Avatar
casper
Default RE: GRRRRRRRRRRR.........throwin engine codes
Nothing you can really do. If its not getting a signal, your gonna get a code. the only thing I could think of is if you could find the allowed range and put a resister in there.
Old Mar 28, 2005 | 02:56 AM
LowSlowNeon
YAY...it gave up and the light went away, even though its still throwing that code. LOL.
