P0341 plz help guyz im stumped...
Old Sep 28, 2009 | 07:15 PM
lusky's Avatar
lusky
Exclamation P0341 plz help guyz im stumped...
hey guyz heres the deal. i pulled a cam shaft pos. sensor error p0340 so i replaced my cam sensor now it pulls as a po341 cam pos. sensor intermittent. at random times it will not allow me to exceed 2.5 rpm and when you try to push it over it starts leaping. i can turn the key off then back on to fix the problem till it happens again. its a 04 neon r/t 5 speed. if you have any idea plz reply ill try anything for a fix... it started randomly and nothing significant happend from when it started. ty for all the help! \
lusky
Old Sep 29, 2009 | 12:04 AM
darthroush's Avatar
darthroush
Section Moderator
Wiring is all good?
Old Oct 1, 2009 | 07:10 PM
fLaMeRED01's Avatar
fLaMeRED01
Could be the cam magnet. did you remove it? They crack easy if over tightened.
