code 0123 help!!
Old Oct 23, 2009 | 04:17 AM
audiobahn4ever's Avatar
audiobahn4ever
Default code 0123 help!!
I got this code and looked it up in my manual and it says the throttle position switch is getting too much voltage. Any ideas on how to fix this?
Old Oct 25, 2009 | 01:14 PM
neisg1's Avatar
neisg1
First of all are you having any symptoms rough idle, high idle or surging? If not then reset the PCM and see if it comes back. If it comes back check TPS plugs and wiring for corrosion shorts opens etc. Also check that the TPS is properly mounted (no loose screws). If all this checks out suspect a faulty TPS.
