2003 Neon problems
Old Nov 10, 2009 | 08:22 AM
dlong's Avatar
dlong
Default 2003 Neon problems
I have 2003 sxt with 80000 on it. The other day, every time I stopped the car, I could hear the coolant gurgling. It was flushed at 5 years and does not leak. We put coolant in it and seems to be fine now. Then today, it stalled out and the oil light came on. Anyone have this problem?
Old Nov 10, 2009 | 01:29 PM
srt4rez's Avatar
srt4rez
If your ride is overheating, make sure your auxiallery fan switch is properly working, when it reaches a certain temperature. Make sure your thermostat is in good condition and the rad cap too. Also check all your fuses and hopefully your head gasket is not leaking. Check your engine bay wirings..make sure nothing got burned The only time an oil light will come on is when there's not enough or too much oil in the engine. Also, make sure there's no oil leaking from anywhere too. Good luck!
