sparkplug with oil
Old Dec 6, 2009 | 10:06 PM
4flower's Avatar
4flower
Default sparkplug with oil
Can anyone tell me what it means when you have oil on your sparkplug? I only have it on one of them, the rest are fine...the car runs okay but idles rough when I am stopped and in gear at a red light and the oil light comes on....it is not burning oil and from what I can tell I don't see any leaks...let me know what you think...thanks
Old Dec 10, 2009 | 12:06 AM
yellow_66's Avatar
yellow_66
Your plug seals are prob worn out.
If you go to Autozone and buy a new valve cover gasket kit it will come with new plug seals that fit inside the valve cover and keep the oil out of the plugs.
Old Dec 10, 2009 | 01:39 AM
contagious19's Avatar
contagious19
yea that is all wats wrong, its an easy fix
Old Dec 13, 2009 | 12:37 PM
mjs182004's Avatar
mjs182004
as far as the rough idle, that will always be there. It's a neon thing.
Old Dec 13, 2009 | 04:18 PM
darthroush's Avatar
darthroush
Section Moderator
What year is your car? I know mine, a 2003, needs a PCM reflash per a TSB. Might be something to look into.
